srw
It's a bit more complicated than that...
Since I happened to be in the area, and my route from my breakfast meeting to the tube took me straight past the front door, I thought it would be rude not to drop in on Brompton Junction. Especially since I wanted to try out a couple of things.
First things first, of general interest. The new integrated brifters. The brake levers are where they ever were, but the shifters are now hanging below the handlebars, to be operated by a thumb. I can see that they might be knockable if you're careless. Being a fan of old reliable tech I was slightly disappointed to see that they're also ratchet levers rather than the traditional haul-the-cable-directly SA levers. The 3-speed shifter is marked with a 1-2-3, and the 2-speed with a +/-.
For the first time ever I rode a Brompton with the flat bars. They're not as aggressive as they look even for a relatively tall rider, and I'm very tempted. I also rode a 2-speed for the first time. It's a very simple setup - the front jockey wheel on the tensioner is fixed while the rear one acts as a derailleur. Very tempting for the lightness - but I've read a bit about unreliability.
On the other hand I'm absolutely not tempted by the 6-speed. Even thinking very hard I couldn't get to grips with the continual double-shift, and I found myself treating the bike as a 3-speed. The mental gymnastics required to remember whether this is a derailleur shift (keep pedalling) or a hub gear shift (pause momentarily) were uncomfortable, and it didn't feel as if they'd get easier. I'd rather get my 8-speed sorted properly, thank you very much.
