Thanks guys - as usual your responses seem to have elicited more questions than answers
I'd either stick with the Racers or take the Contis for more Speed. The Marathons are surprisingly ok speedwise but clearly slower than the first two. I do use them mainly as winter tires. But: Don't get fooled by Brompton's prices for tires. The Racer in 349 ist available exclusively via Brompton, the normal Marathon and the Marthon Plus (that I would not recommend anyway) are not. Street prices in Germany are less than half of what Brompton wants:
The black wired Conti Urban is also way cheaper (and this is not even considered to be a low price for the tire):
Thanks - tbh I'm dubious of prioritising speed over puncture protection as I really don't want the hassle of having to repair a flat mid-commute if it can be avoided. Experiences of the current Racers have been good in this regards so I'm happy to look at comparable tyres but certainly don't want to sacrifice puncture resistance for speed.
Ta for the guidance about pricing - however sadly since (unlike yourself) I'm not in the country of origin for all of these tyres (plus the fact that we get screwed for everything over here anyway) prices seem to be both higher and comparable between Brompton and other suppliers..
I think £26 is the cheapest I've seen the (reflex) Racers for anywhere; obviously less if I get them at 20% off from Brompton.
When you say 'wear' what do you mean exactly? There's no way they've worn out to be unusable in 6 months of normal riding. Unless you skid to a stop every time.
If you meant the tread is looking a little bare - tread on bike tyres isn't the same as on cars. You don't actually need tread for a bike on the road. They don't aquaplane so unless you've worn it through to the protective strip it's not worn.
For the first 7 years of ownership I kept replacing my Marathon+ with the same, but last year I took the plunge on some Continental Urbans for the summer and normal Marathon for winter. The contis are SOOOOOO much better than the M+ in terms of outright speed. But I've had two punctures in 6 months of using them (sub 1,000 miles) compared to almost 8 years entirely puncture free on the M+.
So I'll be switching them out again for the winter and going back to regular Marathon. They are noticeably slower than the contis, but I used them for 6 months last winter and, again, was puncture free.
Cheers - I'm not suggesting that they're worn out, just that the rear is visibly more worn than the front. IIRC when I got the bike (having apparently seen very little mileage) both tyres had around 1.6mm tread depth.
After 600 miles the front is down to around 1.4mm, the rear around 1.0mm.. suggesting that the rear is wearing at around three times the rate of the front (as one would expect) and that the rear will have worn bald (at least at the centre) after around 1600 miles. I appreciate the point about tread and usually run tyres until the bitter end when the punture protection layer becomes visible; however who's to say how much rubber depth is left beneath the tread..
I appreciate the feedback on the Contis - while that doesn't sound terrible I'd like to avoid punctures at all costs of course so am reluctant to look at anything that offers less resilience than what I currently have (if that is indeed the case as I know the Racers are less hardy than the usual Ms).
St John St have the Marathon Racers at £18.99 each.
Spa have Marathon plus on sale at £14 each.
Thanks - those in SJS appear to be the non-reflective / reflex jobs though.. and if sticking with the same basic tyre I'd rather keep them matching!
Looks like the only Marathos for £14 at SPA are 26", unless I'm missing summot..
Fawkes Cycles are doing the rigid CCU for £15.99.
Thanks - seems like a good price but I'm not sure about their puncture resistance, while I'm somewhat dubious of Contis after the undersize tyre debacle encountered last time I bought some.
I've recently changed a rear M Racer on one of my Bromptons after ~3500km. It was in no way worn out but, being about 3,5 years old, had developed a nasty rubber breakout in one very small spot central of the profile that made it prone to a puncture (which I found out by
having a puncture). Else it would have been good for at least another 1500-2500km I'd guess.
So with the 600 miles of
@wafter on the tire there should be plenty of time before a new tire would be needed. Apart from if he loves skidding when breaking.
Cheers - as above this post was started by the fact that I can see some wear and potentially have the opportunity for the next month or so to purchase some replacements a bit cheaper
Just a slightly left field suggestion, but what about Schwalbe Kojaks? I've a set on my folder and have been commuting year round on them for several years now and love them. They last a long time and have good puncture resistance. I have no problems in Winter either, just riding in snow can be a little sketchy at times!
Just for the record, I know I have a 20inch Tern, but they also come in Brompton sizes.
Thanks - I hear these aren't so puncture proof however, so not a direction I want to be heading in!
