chris folder
Hi anyone useing a brooks saddle is there much difference in weight between the brooks and the standard brompton saddle? On the brompton bike build it shows the brompton saddle with 0 weight
The above weights are little less and a little more than half a cup of water, so it doesn't even have to be a good weeNegligble. Have a good wee before setting off if you're that worried about weight.
I just had a look at the bike builder. The brompton saddle shows 0kg as it is the standard kit, and included in the total bike weight already. The Brooks are therefore 100 and 140 grams heavier. The B17s has a shorter nose, so your skirt doesn't get caught in it, so explains why it is lighter.
Just get the titanium railed brooks instead; that's a bit lighter :-)
1/2 kg, give or take.
Depending on which model of Brooks. But a B17 compared to a Charge Spoon. The B17 is much heavier.
But I cant see the concern when we are talking about something that is not a lightweight bike to begin with.
It's buggerall.On the other hand, if it's (too) heavy to start with you don't really want to be adding more even more weight.
That said, Brooks for me every time
