As mentioned in a previous thread, I'm trying to put together some statistics on what parts of typical helmets are most likely to take hits. The idea is that this data will feed through to some helmet designs I'm working on right now, such that a minimum of bulk and weight can be designed in - without adversely affected the protection they give.
Although I'm just a privateer, I'm not messing about here, being in talks with a research neurosurgeon and getting concepts tested out in the digital world using a high strain Finite Element Analysis package called LS-DYNA.
So could I ask ask/plead/beg that all those who have had the misfortune of banging their heads on the ground to look at the following pictures and post up where your helmet took the hit?
And (this is maybe asking too much) if possible could you post up the maximum amount your helmet compressed versus its original thickness???
