gaz
Cycle Camera TV
- South Croydon
Can you cross them?
It's been mentioned before, i've had it said to me and it was recently mentioned in this thread.
Do you think you allowed to cross the solid white line that is often found on the side of a bus lane?
The usual thinking behind it is down to rule 128/129 of the highway code. Where it states
I believe that you are fine to enter or leave the bus lane when you wish.
The thinking behind it is it is a solid white line, so you aren't allowed to cross it. But the rules regarding not crossing a solid white line are only when there is another line on the other side of it, either solid or dashed.128 - Double white lines where the line nearest to you is broken. This means you may cross the lines to overtake if it is safe, provided you can complete the manoeuvre before reaching a solid white line on your side. White direction arrows on the road indicate that you need to get back onto your side of the road.
129 - Double white lines where the line nearest you is solid. This means you MUST NOT cross or straddle it unless it is safe and you need to enter adjoining premises or a side road. You may cross the line if necessary, provided the road is clear, to pass a stationary vehicle, or overtake a pedal cycle, horse or road maintenance vehicle, if they are travelling at 10 mph (16 km/h) or less.
