KneesUp
I'm considering building up another bike, and the frame sets I've settled on all take disc brakes.
To quote Tom Lehrer fictionally quoting Nikolai Lobochevsky - Bozhe moi - this I know from nothing! I have bikes with cantilevers, v brakes, centre pulls and callipers, but have never owned or ridden a bike with discs.
The internets tell me that:
1) Cable discs are ok, but apart from Spyres, all have one piston which makes them a pain to set up and keep aligned and thus take a fair amount of fettling. The nest of the non-Spyre bunch seems to be Avid BB7s
2) Hydraulic discs are good, but you need large, ugly and expensive shifters and may or may not spend the rest of your days bleeding them - I guess this depends to a small extent on luck and a large extent to how well you set them up in the first place
3) Cable actuated hydraulics should overcome both these issues, but Hy:Rds seem to have attracted a large number of disgruntled posters who can't get them to work reliably. When working properly though they sound good - they have two pistons and auto adjust for pad wear. Juin Tech R1s are a closed system so they don't adjust for wear automatically, but they are cheaper and lighter then the Hy:Rds and seem to generally get better reviews.
Would this seem to be a fair summary?
I'm leaning toward the Juin Techs because I can use any old lever, they are relatively cheap and seem easier to live with then pure cable ones, and apparently have better modulation, but any input from anyone else would be much appreciated.
My other 'I've never used discs' before questions are:
1) How long do the pads last?
2) How long do the discs last?
3) How easy is it to change a wheel? I presume that if you have two wheelsets, the discs in theory should just line up (might have to adjust the pads a little for different amounts of wear, but this seems easy on the Juin Techs) but how does this work in practice?
4) Fade - I am about 75-80kg, and ride in reasonably hilly places, sometimes with panniers. I presume fade is not something I need to worry about unless I ride somewhere very hilly with very heavy panniers? Or can it occur in relatively 'mild' conditions?
Obviously the answers to all of these could be 'it depends' but entertain me
