ColinJ
Puzzle game procrastinator!
- Todmorden - Yorks/Lancs border
So, Accy ... the answer is YES - GO AHEAD AND OVER-INFLATE YOUR TYRES!
Did you mean tubular? Tubeless shouldn't puncture as easily when hitting potholes or debris on the road, or so I have been told.
.Ah, ok.No I meant tubeless;if the OP thought his standard clinchers were under-inflated dunno what he'd make of tubeless as they are run at even lower pressures usually.
Tubeless are ace over pot holes and rough roads,got some nice cobbled sleeping policemen here which are knackered due to lorries and buses and with the tubeless can give it the berries over them.
I've 110psi(recomended) in 2.20 tyres!As they are 25's then you should have them between 85-90psi,the days of 100psi+ were for really narrow tyres;you'll probably find that you are less likely to pop a tube over pot holes running a lower pressure(actually think most pinch flats are mostly due to poorly installed tubes).
Good job you don't have tubeless though,,,,,
I wouldn't worry about sealant mess, Colin. I've just changed a tyre this morning in fact and whilst I did remove the tyre over a towel, said towel did not receive a single drop of the sealant (and no, it hadn't all dried out!). It requires a little care, but really not very much care. As an experiment, having removed one bead, I put a tube in, reseated the tyre and pumped it up, just to make sure that I could. That was also easy and non-messy (I'd tipped the sealant out before putting the tube in). Clearly, I did have to wipe the tube down once I'd made sure it worked OK in the worn out, tubeless tyre. Oh, and that was all without resort to any tools beyond my hands, so that aspect wasn't difficult either. All most reassuring![]()
When i said i'd pumped the tyres up to 100 psi but still felt soft, well i hadn't pumped them up to 100 psi, more like 50 psi! On last Wednesday's club ride someone thumb tested them and said they felt more like 40 than 100 psi. I insisted my track pump gauge was accurate. The other day i decided to pump them up again and the gauge showed 50 psi. I hadn't been pressing the nozzle down on the valve enough for it to register correctly. Ooops,silly me.
