Carpet knee kickers - any good?
SpokeyDokey
69, & my GP says I will officially be old at 70!
I have some noisy floorboards that need attention that are under fitted carpet.
As ever, finding someone to undertake smaller jobs in the Lake District is a monumental task.
I have found knee kickers (with adjustable length spikes) online.
Has anyone removed & relaid a carpet with any great success using one?
NB; the carpet will only be lifted in a specific area not in its entirety.
Any shared experiences and tips appreciated.
Thank you.
midlife
All the carpet fitters I know moan bitterly that they have knackered knees because of using them.
In the past I have lifted parts of carpet, screwed down floorboards and just put the carpet back where it came from.
SpokeyDokey
SpokeyDokey
I think my knees will be ok. It's only a small area that needs lifting and relaying.
How did you retension the carpet back onto the gripper strips?
Glasgow
I did fit a carpet in a small room without knee kickers, it was fine, the carpet wasn't very heavy or very thick.
It stayed put for years!
Imo, if you just lift a small bit from an already fitted carper @SpokeyDokey, the carpet will fall back in place without much effort.
I would try without knee kicker first, if you are not satisfied then buy one.
Would be better to borrow if possible, because when are you ever going to use it again?
Dave7
Cheshire
I did similar to a small section of carpet and because it was already 'stretched'** it fitted back into place with no problem.
**I am assuming it was stretched but either way it just went back into place.
Years ago I made my own knee kickers. Small nails through one end of a plank of wood sticking out about 6/7mm, a couple of layers of carpet fastened around the other end to knee. It worked a treat to carpet a few rooms, but now I pay someone because i was young and poor then and now I'm more lazy.
oxoman
As an electrician I've pulled up my far share of carpets in the past and refitted them mostly without problems. Only times I've had issues is when the original carpet fitter has stretched them to fit as probably a little short. I used to have a cheap stretcher from either toolstation or similar that did me till I gave it away. Just try refitting and shuffling it back, if gripper rods fitted just tuck behind and push it in. I used to use a clean bolster chisel. Good luck.
