Cassette replacement - SRAM
S-Express
Get the SRAM chain if it's cheaper to buy it that way - if not, it doesn't really matter.
Hacienda71
Run whatever ten speed chain is best value. I tend to run Decathlon branded KMC Sl 10 speed chains as they are cracking value. You can also run any Shimano Sram compatible cassette with the ratio you want. Basically any 10 speed chain and any non Campagnolo cassette.
MrGrumpy
Huge Member
Fly Fifer
Interesting Decathlon branded ?? usually change the 10 spd chain on the summer bike once a year.
http://www.decathlon.co.uk/10-speed-lightweight-bike-chain-id_8280937.html
seems good value if its the same ?
Hacienda71
MrGrumpy
Huge Member
Fly Fifer
Yep, comes in a Btwin box but kmc stamped links. I suspect it is actually the EL not the SL looking at the weight but still great value as fully branded even on offer they come in at north of £20
Wiggle showing it at £21 odd, so that`s a proper bargain ! Picked up a SRAM PC1091 last year for about £15 i recall from Ebay same place has them back up at £26, so good to see something fairly similar!
http://www.wiggle.co.uk/kmc-x10-el-silver-10-speed-chain/
Hacienda71
No they are like the one that MrGrumpy links to above. :okay:
Ok, sorry for my ignorance but can someone explain the difference in these 3 please?
http://www.chainreactioncycles.com/kmc-x10-73-10-speed-chain/rp-prod120675
http://www.chainreactioncycles.com/kmc-x10-93-10-speed-chain/rp-prod120676
http://www.wiggle.co.uk/kmc-x10-el-...ww.skimlinks.com&utm_term=78888&utm_content=0
Do they basically all do the same job but are made of different materials/treated differently so that one is better than another somehow - in terms of durability maybe?
If so is this the order of worst to best? - X10 73, X10 93, X10 EL
Hacienda71
I suspect although I haven't checked that the lighter the more expensive. Weight weenies are willing to pay to shave a few grams here and there. :whistle:
Hacienda71
The RRP on the EL is £44:00 @ 262 grams, the lightest chain is the SL RRP is £69:00 253 grams. £25 for a 9 gram saving.....
