Tks for explanation
phil_hg_uk I am not a member, I am a free man !!!!!! Location We have hills here to keep out the riff raff 19 Jul 2012 #2 Assuming you have it in auto mode then it should mean how long your ride has taken.
OP OP N novetan Über Member 19 Jul 2012 #3 phil_hg_uk said: Assuming you have it in auto mode then it should mean how long your ride has taken. Click to expand... If I ride from pt A to C with a coffee break of pt B in between, it measure the total time taken from pt A to C including the coffee break? So If I want to measure the latter part of B to C, means I have to reset it. Is that correct?
phil_hg_uk I am not a member, I am a free man !!!!!! Location We have hills here to keep out the riff raff 19 Jul 2012 #4 novetan said: If I ride from pt A to C with a coffee break of pt B in between, it measure the total time taken from pt A to C including the coffee break? So If I want to measure the latter part of B to C, means I have to reset it. Is that correct? Click to expand... If you have it in auto mode then the clock will start and stop when you do so it should only show the actual riding time. If you have it in manual mode then the clock wont start and stop when you do so it will show the time including anytime you stopped for.
OP OP N novetan Über Member 19 Jul 2012 #5 Tks. I just realised it also. I just did an experiment at home by spinning the wheel. How come i didn't think of that.
