Gez73
Hi all, a query regarding chain removal and replacement. If I am using a Shimano chain and I need to remove it for whatever reason, is it the case that I can only rejoin it with a Shimano pin or would a KMC powerlink be okay to use? I have read in a manual that Shimano chains don't work with powerlinks and require the pin to be used. Also if I have removed a full link what would I use to replace that? I purchased a new Shimano chain and it has a split type pin included for joining the links but I will need a replacement pin if I need to remove it or will I?
Help appeciated. Gez
