trustysteed
I finally got up the courage to use some of the tools in the bike tool kit I bought over a year ago. Namely the chain removal tool. Was amazed at how easy it was to remove a link and fit a powerlink for cleaning purposes.
Of course it was easy, especially if you practise. Which I did by removing a wrong inner link in the first place (and I had even thought about it carefully beforehand!) and so had to then remove two outer links to resolve it.
Result, a chain two links shorter than normal! Hasn't affected the drive although the hanger is angled forward about 45 degrees when in the lowest gear. Arse! Still, when I get around to buying a replacement chain, I will know better next time. Strangely, the wife was reluctant to let me put a power link in the chain on her brand new bike.
Next step, cocking up the sprockets with the chain whip tool!
