Chainring “pin” thing.
dickyknees
Anglesey
Any ideas on what these are on my 50 tooth chainring? One looks to be missing.
Deep clean still in progress!
Having a second look, the “missing” thing’s location hole looks a different profile to the others.
Threevok
Growing old disgracefully
South Wales
Would there be a pin on the inside of the driveside crank, that fits snugly into that recess, to catch the chain, should it slip between the two ?
dickyknees
dickyknees
Anglesey
The pins/ramps are to give better/smoother shifting, or possibly a 'chain catcher' as tv says. If it works don't worry about it. Looks like it's not long for this world anyway.
Yes I was thinking that but have nothing to compare it to. Would you replace now?
the snail
Chippenham
Yes I was thinking that but have nothing to compare it too. Would you replace now?
I'd keep using it, IME you can use chainrings until they're completely FUBAR, so long as you're not getting problems with chainsuck or shifting gear. I usually replace them when I'm embarassed by the state of them.
dickyknees
dickyknees
Anglesey
Thanks for the help.
I’ve started looking for replacement rings but it’s a minefield trying to find compatible chainrings for the old Shimano 4600 in stock!
Ajax Bay
East Devon
Any 50t chainring will do.
5 bolt, 130mm BCD.
This: https://www.bikester.co.uk/shimano-tiagra-fc-4603-chainrings-357797.html
Doesn't matter that it's a 4603 (triple).
