Funtboy
- London via Jarrow
Hi all,
My back wheel has started clicking at me. In fact it's more like a cracking sound to be honest (clacking?). It goes mental when I brake (disk) or go over bumpy ground.
Anyway, I suspect it's because the bits where the spokes cross need lubrication. I haven't had time to fix it properly (I only managed a few spokes before I went to work) but would like clarification on a few things.
In the normal state of things, should there be movement between the spokes at those cross-over points or should they be drum-tight and not move at all?
If we should expect movement, is it the case that we should always keep the cross-over points lubed up as a matter of course?
I ask the last question as it seems some of the spokes on the side with all the cogs (cassette?) seem to have furrowed a groove into their neighbour so even if I do lube it, I reckon it'll still make a noise popping out of the furrow.
If this is the case, what do I do? I'm kind of being impatient as I haven't actually done the full job yet but I'm dying to know...
Many thanks in advance...
