Continental 4 season tyres
e-rider
Banned member
South West
I have just bought a pair of Conti 4 seasons tyres in 700x23
After fitting the tyres one looked bigger than the other. I have attempted to measure them with a digital caliper and indeed one tyre measures about 2mm more.
Both are labelled as 23mm, they are fitted to the same rims with the same rim tape and the same inner tubes.
Is this common? Is a problem with the manufacturing? They are 'handmade' so probably yes!
Loch side.
My guess is that one 23mm one escaped the batch and shacked up with the 25mms before the labeling happened. Do they both run true?
e-rider
e-rider
Banned member
South West
they both had 23 on the box and they both have 23 molded into the rubber which must be done during manufacture, not afterwards i would think
Svendo
Walsden
You could swap them on the wheels and see if they still measure the same. If too much hassle to return to vendor put the wider on the rear like those force/attack tyres.
e-rider
e-rider
Banned member
South West
I'm sure they are seated correctly. I'm sure that one is either oversized or undersized. I will not return them as they both seem to be fine. I'll try swapping them round and see what happens, otherwise larger on the rear makes sense like the force/attack tyres - unfortunately the larger tyre is currently on the front!
