conversion kits
madcyclist09
I have thought of buying a Ebike but I want to keep the bike I already own which are the best ones I have looked at swytch but they only do fromt hub motor but I know they are working on a rear motor I have also looked at boost
recommendationsTIA
Hilldodger
sunny Leicester
I've converted several of my bikes to electric due to my Parkinson's and each of them has their merits. I have 3 Swytch kits (bought off ebay still in their boxes and about half the price) and found them great for shorter trips but the range isn't great and being cadence sensing means hill starts are tricky and the steering is heavy. My gravel bike has a TongSheng mid drive which is a cost effective torque sensing motor and it's been great so far with no issues, but compared to my Raleigh Motus with the Bosch mid drive, it does feel a bit lower quality. I had a Carrera mountain bike with a Bafang rear hub motor for a while and that was generally quite good - until you have a rear wheel puncture.
raleighnut
More tricky since the 2016 regulation change, we've got 2 cyclotricity front kits (250w) and they have been faultless but were fitted in 2013 and 2014 so have no sensors and are 'thumb throttle only' speed is governed by the controller 3 phase frequency being limited so the wheel will only spin to a certain RPM (3 phase 'hall effect' motor)
Hilldodger
sunny Leicester
ktmbiker58
A few years ago I put a Bafang mid-drive kit on a Pashley trike that was very successful, it was 250W and fully legal, it fitted a standard BSA BB. I also fitted one to an On-One MTB frame but that took more work because the wider chainstays fouled the back of the motor assembly so I had to heat the chainstay and put a flat on it. Other than that they both worked well and was a good way of getting a bit more life out the trike and the bike!
Drago
The Urban Fringe
The regs are badly written, which affects kits. I guess the kits were never anticipated then the lawmakers went to work.
Even a kit whose characteristics are in full compliance with the regs isnt technically legal - the law regards the person fitting it to the bike as the manufacturer, not the builder of the kit, and the manufacturer is responsible for compliance with regulations and, crucially, the fitting the compliance plate/decal as certification.
As a "manufacturer" you must be registered with the vehicle certification agency, or hold DVSA approved certification, in order to prove compliance with regulation 168/2013.
Clearly no individual fitting a kit at home is going to hold such certification, so cannot manufacturer a road legal EPAC.
Widnes
On top of the "legally fitting it yourself" thing
You have to be careful to get something where the motor assist cutoff CANNOT be changed
technically - if the cutoff can be changed by a computer - possibly an app on a phone - then it is not legal
even if you have it set to 15.5 mph
It would have to be a very pedantic copper to test it and find it cuts off at 15.5 mph but still prosecute it
but given some of the cases in the news at times then if you got one of them and tried to get it back
then proving it was legal might be complicated
and the sticker than "proves" it is legal - is available on the WWW - at least on mine I can say that it was put they by the manufacturer
proving it was genuine to a grumpy copper when he can find the exact same thing in 2 minutes as sticker would be a problem
Of course - the seem to be mostly testing them using a rolling road thing - and any decent person would say that if it doesn;t have a throttle and the motor cuts out at 15,5 mph then they may as well say
"Nah - we could look for something - but things like this are not the problem"
but I would doubt that even mine (Raleigh with Bosch motor) would come out totally clean if someone wanted get really grumpy
e..g how much leeway is there on the cutoff speed - it is cuts out at 15.7 mph of 16 then ........
I mean - I have not tested it on a proper machine myself and just using the speedo on the bike is certainly not accurate
Hilldodger
sunny Leicester
On most of the ones I have (I've not tried with my Motus) there's a setting in the menu for wheel size and you just select a smaller size.
Widnes
Yes - actually can;t be done on my Motus - Bosch are like that
but doing so also means the speedo is wrong all the time
as is the range displayed and mileage done
same as moving the magnet from the wheel to the pedal and the detector as well to detect it
Mike_P
Harrogate
Maybe I was unlucky but a TongSheng mid drive packed in on me after just over a year. That was early 2020 and what I had spent on it i recovered in buying a new 2019 Giant ebike that was heavily reduced.
Drago
The Urban Fringe
They are available, but are very poor.
There is also a side issue, in that using such a sticker is a far greater offence.
Get caught with a derestricted ebike and youll get a fine and some points.
Get caught using a false instrument with intent to deceive, particularly if the intent is to deceive a copper, and you'd do well to escape with a suspended sentence.
Widnes
Thanks - didn;t know that
I reckon you would really have to annoy the copper to make him go as far as that
but then - some people do seem to really try!!
