Thanks for your thoughts - my arms are straight and I did take another set of shots with them slightly bent, however I figured straight would give the most consistency in position, rather than allowing the possibility of variability of arm bend to skew the results. My camera remote isn't working so each shot required me to set the 12 sec. timer, scuttle back to the bike, hastily climb on top and assume the position before the shutter fired; so I didn't have much time to concentrate on my position!Your arms look pretty straight in the photos?
I do usually ride with my arms slightly bent but due to a lack of flexibility and my shorter upper body need more stack and less reach than the average bear so on a bike with "typical" geometry it's more likely that I'll be riding with straight arms. I need to look in typical arm lengths as my span is fairly wide but I think this could be due mainly to broad shouders; which when coupled with average / short arms would make the reach problem worse.. could do with finding some decent anthropomorphic proportions data but so far a definitive source is proving illusive!
Thanks - I very much appreciate your encouragement although take the depth of information in my post as an indicator of how much this issue has got under my skin / how desperate I am to reach a satisfactory outcome! If nothing else I love hoovering up knowledge and information, so twisting in the wind notwithstanding at least it feels like I'm learning something!Personally i would go Genesis as most upright, i always go 58cm frame and 6ft3ins. XL's always feel too much of a stretch Good post btw.
The Genesis is certainly the most upright; which isn't surprising given that has about 33mm more stack at the bars than the Giant and 41mm more than the Boardman. Even the much greater reach to the hoods (29mm over the Giant and a whopping 44mm over the Boardman) isn't enough to make the bring the back angle in line with my two existing bikes, but it does make it feel less controllable (from what I can tell from sitting on it in my living room!).
Thanks and yes; while 100mm seems to be the standard stem length on "medium" road bikes I was a bit surprised to see that it's over 100mm (despite claiming otherwise!) on the Genesis. I've certainly considered shorter stems (having already taken this route on the Boardman to get it somewhere near comfortable) - it seems that road stems only tend to go down to maybe 80mm before you start getting into MTB items (which I assume can be a lot shorter due to the much slacker head angles typically found on MTBs).Interesting to see the long stem on the Genesis. My Kona looks reasonably similar in set up to the Genesis, however, with a much shorter stem, 70mm on the Kona as opposed to 100mm on your Genesis. This runs contrary to bike fitting guidelines, which suggest that with an ideal stem length you shouldn't be able to see the front axle. I find though that the short stem and wide bars provide a really comfortable ride and easy to ride off road as well as on. As @vickster says, your arms look too straight, shortening the stem would sort that problem out and probably make it more comfortable. Overall it looks generally ok and like it needs a tweek or two to make it perfect.
Did your Kona come with a 70mm stem or did you fit it yourself? If so what length was the original and how did you find the effect on handling? Sticking the 90mm stem on the Boardman definitely made it a shave more "twitchy" but certainly not to the extent that it was unpleasant or unmanageable.
Going back to the possibility of a small frame, by comparison to the medium pictured the reach is only 10mm less and the stack 21mm less.. which at the bars brings it a lot closer to my other two bikes and makes me think that it would be a better fit; especially since I've had to work to reduce the reach on the other two bikes with replacement stems and bars.. I just have my reservations about the shorter cranks, lesser seatpost insertion length and shorter frame reach on the small CdF (which is 17mm shorter than on the Boardman, but with the original stem gives pretty much identical reach.
On the flip side, it does worry me that I'm possibly looking at this the wrong way - seeking to account for my short upper body by going for smaller frames to reduce reach, when perhaps I should instead be looking achieve the same goal by increasing stack instead.
For what it's worth (and for anyone not yet asleep) below are the dims for all these bikes; the first three being confirmed from my own measurements, the latter three being based on the differences in published values between the different frame sizes relative to my own measurements. The Adv. bars are the ones currently fitted to the CdF 30, the X-Race bars being those fitted to CdF 20 I test rode a while ago.
Sorry the formattings a bit messed up; although I'm fairly impressed I could get away with pasting from Excel at all! "Bar" refers to the tops / the portion of the bar is clamped by the stem, the rest should be fairly self-explanatory
Feature | Giant OCR3, Medium, Current Spec, Measured | Boardman RTC, Medium, Current Spec, Measured | Genesis CdF, Medium, Adv. Bars, Measured | Genesis CdF, Medium, X-Race Bars, Inferred | Genesis CdF, Small, Adventure Bars, Inferred | Genesis CdF, Small, X-Race Bars, Inferred |
Stack, Frame, mm | 545 | 561 | 596 | 596 | 575 | 575 |
Stack, Bar, mm | 646 | 638 | 679 | 679 | 658 | 658 |
Stack, Drop, mm | 519 | 515 | 541 | 551 | 520 | 530 |
Reach, Frame, mm | 390 | 393 | 386 | 386 | 376 | 376 |
Reach, Bar, mm | 463 | 461 | 469 | 469 | 459 | 459 |
Reach, Drop, mm | 533 | 522 | 567 | 547 | 557 | 537 |
Reach, Hood, mm | 568 | 553 | 597 | 577 | 587 | 567 |
Stack/Reach, Frame | 1.40 | 1.43 | 1.54 | 1.54 | 1.53 | 1.53 |
Stack/Reach, Bar | 1.40 | 1.38 | 1.45 | 1.45 | 1.43 | 1.43 |
Stack/Reach, Drops | 0.97 | 0.99 | 0.95 | 1.01 | 0.93 | 0.99 |
Standover, mm | 765 | 783 | 808 | 808 | 784 | 784 |
Wheelbase, mm | 978 | 992 | 1033 | 1033 | 1021 | 1021 |
