Panter
Just call me Chris...
- Sittingbourne, Kent
Regarding my transmission.
Chain number 2 is now worn to the first indicator, so I was just going to get another replacement.
However, when I checked the cassette, some of the cogs are a bit shark-toothed although most are fine.
So, should I change cassette and chain now or should I now just run them both into the ground and then replace both (especially with Winter fast approaching?)
I assume its not worth just chainging the rings that are worn as presumably the ones that look Ok will be on the way out too?
If I do just run them into the ground, will the front chainrings suffer at all?
Edit: Bike is an SCR3 '07 which has done a smidge over 2000miles if that helps...
