Steve07711
Hi All
I have a 2012 CUBE Peleton pro-race road bike and from almost the day I purchased it the rear gear shift has not been right , when first adjusted it will shift down and up the gears ok but after a few miles will begin jumping gears or become really slow shifting into the highest gear. My LBS have worked on it a few times and replaced the rear derailleur and sprockets as well as fitted new cables but the problem always comes back. They think it may be due to the internal routing as it improves if you spray lube down into the frame and into the front shifter but they have basically given up. Has anyone else experienced the same issue and if so have you had any joy getting it sorted as it is now driving me crazy ? It is not a massive issue as I have done many miles this summer but it is just bad enough to annoy the hell out of me on my daily commute.
