MontyVeda
- Lancaster... the little city.
I've got a sheet of copper plate at 0.7mm thick that needs cutting (a curve, just to be awkward).
I figured my junior hacksaw would do the trick but that's proving tricky; not enough teeth and the force is bending the sheet when i'd like it to remain perfectly flat.
My Jigsaw blades for metal don't seem to have any more teeth per inch than my hacksaw, and looking at screwfix I've got got as finer blade as one can get. Would sandwiching the sheet between some plywood help?
Or would i be best off buying a coping saw with an ultrafine jewellers blade?
I guess at 0.7mm thick, I'd be looking for a tooth pitch of around 0.2mm... if such a thing exists??
Thanks in advance
Thanks in advance
