That's Nov 2 done. Not entirely flat but never steep so worth a go....
Stage 2 done, must be working hard, felt sick again! Still trying to get used to this smart trainer lark, I seem to find I am changing gear all the time when I'm pretty sure on the road I would grind over a lot of these small rises. Having said that not looking forward to stage4!!
Thanks for the advice Jim. I think my problem is looking at the gradient change bar on the bottom left two much an reacting to this. I find even with video you can't see the rise in the road like you can on real roads so on real roads, you tend to wind it up before and push over the top before the gradient kicks in if you see what I mean. For the next one I might try covering that part of the screen over and try riding on feel more.Hi @ScottTilley thanks for heads up on your stage run. It appears that all rides are being reviewed due to weight.. just another Bkool quirk..
Are you getting out of the saddle on the lower accents? I don’t have the power to drive up the hills and therefore I have to either climb out or spin.. do be careful on up and down courses where you have to change gears rapidly, as some of the profiles can shred rear derailleurs.. which can pass through your carbon right seat stay...or is that just me...
I'm having a go tomorrow, hopefully!Stage 3 done, mountains next!
I'm having a go tomorrow, hopefully!![]()
Stage three done, Garmin says I need 62 hours to recover... Which is ten hours less than last weekStill needs ratifying with the weight issue again
Scott
Thanks Jim, have you done your suffering yet!!All done Scotty..![]()
Thanks Jim, have you done your suffering yet!!![]()
