dan_bo
How much does it cost to Oldham?
Washing line.
Correct. I just haven't checked either on either!You just need the Wattage and length of time to dry clothes
... is that the dehumidifier is used in a part of the house where its heat output is useful, whereas the tumble dryer heat is wasted in my cold cellar (much of that heat probably warming up the foundations of the building rather than coming up into the house).Now it pretty much only goes on when the heating's on anyway so the heat it produces doesn't go to waste.
Yes - when we don't have perma-drizzle!Washing line.
Dehumidifier. We use an airer, load it up, and pop a dehumidifier next to it blowing air over the washing, occasionally turning the washing. We can dry 2-3 loads this way. You do need a smaller room ideally, although we're managing find in the conservatory.
Drying clothes, heat loss and humidity are all issues which can be alleviated with MVHR system.
They're into the 90s% range for heat recovery.
So the energy used in creating heat is not lost, but redistributed throughout the building. Moisture is removed to keep humidity levels in check.
Very few buildings have MVHR, but it should be standard on all newbuilds.
I fitted it to a newbuild, it worked extremely well, keeping all rooms throughout the house within 1 °C and humidity spot.
Providing you get the correct type of dehumidifier, it would definitely work. If you go for a high capacity one, trust me, you will be gob smacked how much water it draws out of the air in a relatively short amount of time!Dehumidifier might work ?
Interesting thread , currently got two clothes horses up. 5 of us so washing is on all the time. The issue is I’ve restricted the heating , drying clothes was not an issue in the past but it is now. Tumble dryer has been banned from use. Dehumidifier might work ?
