I am soon to become the owner of a new bike .... my first to be fitted with cable disc brakes. So cue a couple of rookie questions:
(1) Is there any difference to the technique of removing/refitting the wheels that I should be aware of?
(2) It strikes me that cleaning the cassette now potentially requires greater care to avoid cleaning products/oil splattering onto the rear disc brake due to its proximity. Is there a technique to avoid this?
Any advice for the best way to clean the brakes that won't leave them squealing the next time I use them after washing the bike?
All sensible "do"s and "don't"s gratefully received.
1) No, but keep in mind that as you tighten your skewers/through axles, you move the frame (or fork) which both house the caliper(s) closer to the disc rotor, meaning you may upset your brakes and cause rubbing.
To avoid this, either learn to tighten your skewers 100% accurate each time or just not take the wheel off at all. - For general ease, I avoid taking the wheel off as much as I can when I have it 100% dialed in to perfection.
2) It's common sense but even if you avoid any such contamination your new disc brakes may still squeal & squeak as they bed in, so don't panic if you hear it on your new bike.
- My advice is clean your brakes by spraying brake cleaner (or some kind of alternative like industrial cleaners) onto both sides of the rotor and then gently apply your brakes while spinning the wheel, to soak the degreaser into your pads and allowing them to deposit grime & dust back onto the clean rotor, wipe vigorously and repeat the process a few times until both your pads and discs are free of the majority of brake dust and grime.
It's worth mentioning that you should never clean your brakes until you have gotten every last spec of dust off them - They need to have Brake material deposited on them in order to stop properly - It's why your new, unused rotors won't stop at all.- Using strong degreasers too much might cause you to have to bed everything in.. Again.
- If you use any type of industrial cleaner on your brakes, keep in mind that alot of it does not evaporate meaning it may cause squealing and poor braking for a few miles as it will hardly allow brake material to bite properly with the rotor. To prevent this, Ensure you thoroughly rinse your rotors with plain/soapy water if you use those kind of cleaners, and dry them after.
- Do not feel compelled to use specific brake cleaners and heavy degreasers to just clean your brakes. - Soap and Water is an effective way to clean your discs & brake pads. - Some manufacturers even recommend this; I only personally advise you to use such types of Specific products if you find your pads are contaminated with something.
