Disc brakes on road bikes
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
Yes indeed, I should have made that clear. My post wasn't anti-disc or anything but just an observation that in the motorcycle context discs supposedly had worse wet weather performance than their predecessor (drums), though for pedal cycles they are apprently an improvement over rim brakes in the wet
Drum brakes would be a good choice on a utility bike. Sealed off from the weather etc.
Profpointy
I've seen such bikes, mostly or always with drums on the back and callipers on the front, which seems the wrong way round if anything
Vapin' Joe
Formerly known as Smokin Joe
That wasn't my experience at all. Drums were by no means water tight and when they did get water in they took a while to dry out. Even the early undrilled discs cleared the water in a single revolution and were a big improvement.
Profpointy
My own motorcycling was later than the drum era, even drum rears, so I confess I was repeated stuff I'd read rather than experienced. That said, even on my 80s drilled cast iron discs there'd be a disconcerting delay in the wet before the water was shed. Never experienced drums, apart from car rear brakes. Pain to maintain compared to discs certainly
Dogtrousers
Lefty tighty. Get it righty.
Regarding discs being better than rim brakes in the wet, I don't doubt it it makes sense but...
Aside from steel rimmed wheels, I've never had a problem with rim brakes in the wet, and I've done my fair share of wet weather riding. I've never thought "Oh lordy, it's raining, my brakes will be compromised. This could be (and probably is) just because I'm used to them. But I wouldn't say that rim brakes are noticeably bad in the wet, even if it's true that discs are better (which I'm prepared to take on trust).
Steel rims, yes. I did ride a very old bike with steel rims in the rain a while ago and the brakes were hilariously bad.
Punkawallah
Just to clarify, is it worse or better with discs? I've never ridden a disc braked bike
The nice boys from GCN did a test, and found that for the same bike on dry road at 56kph rim brakes stopped it in 4 seconds, disc brakes in 3 seconds.
Dadam
SW Leeds
Re squealing. The Tektro hydraulic discs on my Vado SL squeal for the first couple of seconds when wet and cold. Usually when setting off after it's been raining when locked up, then go quiet when the water has been shed. I've ridden it in light rain but not a torrential downpour.
The Tiagra hydro discs on my Gain and Felt bikes never squeal. The only noise they make is a kind of rasping grasshopper susurration on heavy prolonged braking, wet or dry. @ColinJ and I got caught in a cloudburst leaving Craggies café on the January forum ride, and then immediately had a steep descent into Mytholmroyd. There was no squealing from my brakes, just efficiently converting kinetic energy into heat with gentle finger pressure.
While rim brakes, and to some extent drum brakes are fine, it is better to go with the flow. Disc brakes have come into their own, and parts for them will be what is easily available at the bike store.
cyberknight
I can vouch when its really wet and your going down hill and need to stop rim brakes have given me a omfg am i stopping moments and even the cable discs i use i knew the braking would stop me .
