Discontinued saddle woe
lejogger
Wirral
I currently sit astride a Fizik Arione K3 saddle on both my bikes. I’ve always struggled to find a ‘perfect‘ saddle, but this is by far the closest I’ve come. By far.
https://www.mybikereviews.co.uk/fizik-arione-k3-tri-saddle-carbon-review/
It was actually designed/marketed as a triathlon saddle (k = Kona) so it‘s got a decent amount of padding compared to a standard arione, especially on the nose - ideal for those of us who like to get on the rivet and thrash out the occasional fast one (comparatively).
The saddle on my best bike has been a bit creaky of late, and when investigating today I found a significant crack on the underside. The K3 however is now a discontinued model so unless I strike it lucky on ’the bay’ I’ll need to find something else.
I’d love your recommendations on something similar... and possibly something that corrects its only fault, of being a smidgeon narrow.
Many thanks in advance.
si_c
Wirral
You can still find it if you don't mind the price being ridiculous.
lejogger
lejogger
Wirral
Not sure I’d chance that website with that amount of cash!
Am actually interested in alternatives here, given as much as this is the best saddle I’ve had... it isn’t perfect. I still get sore when rides go to 2-3 hours, and I’m most definitely a saddle fidget, always moving about trying to find a comfy spot.
si_c
Wirral
Have you measured the dimensions on that saddle? I'm thinking max width, front to back width and width at the nose.
Probably worth thinking about that as a starting point and then comparing with new ones.
lejogger
lejogger
Wirral
Width wise it’s 128mm which despite the relative comfort is too narrow for me if I’ve measured my sit bones properly. Hence the hope for alternative recommendations. 300mm length i think. but I’m not sure how important this is... would I move around less if I found a saddle with a more suitable width?
rivers
How far can I go?
Bristol
Is there a shop local to you with demo saddles? For a small fee you can test different saddles for a certain amount of time (my local shop is a week per saddle) to see if they work for you.
wafter
Oxford
Might it be worth contacting Fizik? Play the longstanding loyal customer, distraught that your beloved saddle has died and that you can't find anything as good. If they're any good they'll at least give you a recommendation of something in their range that's genuinely equivalent / close, if they're really good they might try and ply your repeat business in other ways..
lejogger
lejogger
Wirral
That's a good point. I may well do that.
I had a dig around in my parts bin earlier in the week and found a Fizik Arione Tri2 which seems to be an earlier iteration - without the carbon bits and with manganese rather than Kium rails (?!?). Haven't managed to get it exactly set up the same yet, but will do the trick temporarily... the major problem being that it's the wrong bloomin colour! The red back kind of goes, but the white body is a horrific crime coupled with the black bar tape :wacko:
546498
You need white or red bartape...simples :okay:
That bike looks wickedly uncomfortable!! :wacko:
And your pictures look to be seriously wonky! :ph34r:
lejogger
lejogger
Wirral
Uncomfortable? How? Saddle to bar height?
It's the angle of the clamp arm in the stand that's wonky - I hope! :whistle:
lejogger
lejogger
Wirral
Ah you mean the pictures on the wall... not my photography skills. Yeah, they're precariously balanced and I think they move when the window's open/door closes.:blush:
I'll get round to sorting at some point :okay:
