Sheffield_Tiger
I am quite disgusted, in fact I'm bordering on angry that such a rip-off product should be sold
Only thing is, I'm disappointed too as the Smart range of lights are, in my experience, the most versatile for mounting on racks, seatposts, trailers, pretty much anywhere which is why I stuck with them this year after some problems with water ingress last year with the smart 1/2 watt
I "upgraded" this year to two 1 watt units. The switch is rubberised instead of the "press the thin bit of casing" affair and there looked to be a substantial seal around the body and the backplate. It looked like the newer ones had addressed the water ingress issue.
I've had these two lights for two weeks - no longer. Pretty much every day I have had them mounted on my trailer - that's behind the wheels away from any upward spray and they've been fine
THE FIRST TIME I've mounted the light on my rear rack (using the Smart bracket disigned for such fitting) I have got to work and my light has changed modes and will not switch off - it's not even raining, that is purely from road spray!
Two lights cost about £35 and what bloody use are they? I'm considering raising an issue of "not fit for purpose" - what if I was on a dark country road in the rain and my lights start changing modes into "off" mode without my knowledge?
What other alternatives are there out there for a bright light that will mount to the tubing of my trailer and onto my rack?
