keithmac
We used to get rollocked for using grammar such as 'mumering' and 'wors'.![]()
I did notice after I posted it but just couldn't be bothered to edit it
.We used to get rollocked for using grammar such as 'mumering' and 'wors'.![]()
.Airfield ground lighting. Oh how I hate you. Yet love your simplicity at same time.Martindale VI13800 and PU for us up to 3-ph LV. Change to ALS HV for ground power and AGL, then big sticks @ 11kV, followed by Pfisterer Phase Comparators at 33kV.
PROVE your tester (potential indicator, PI) works on a known live source (either proving unit, PU, or another circuit which you know is live, not ideal)
TEST the circuit on which you want to work using your PI.
PROVE your PI still works by testing on PU
Glad you are sorted but I would stay clear of them ever again, there were far better ways of doing it than bodging it like that
Some folk make frightening bodges. In my brothers house we found the oven was plugged into a standard extension lead under the units and not wired into a separate circuit.
All they should have done is create a spur off the socket & mounted a surface mount socket behind the microwave, about a 10 minute job.
Wrong it's a fixed load so as long as the circuit operates under fault ( very different to overload/over current) in the required time it meets requirement . Yes even fan ovens . Reg 433.3.1 (ii) off the top of head .Not necessarily wrong. We had a big 900mm cooker (albeit with gas hob) that was actually meant to be on a 13amp plug socket. If you did it via a cooker spur it'd be wrong in theory as you'd not be fused correctly
.Microwave could get him yet, when he goes to move it again!!I have to say I get a bit concerned when I see threads of this nature, it's always a relief to see the OP still posting as the thread draws to a close.
Most flexed fan ovens are 15A rated so it is not technically permissible to use a 13A plug to BS 1363-2: 1995 inc A4 :2012
