Tin Pot
That brings only a selection of pluggable extensions. And one 'box' with no cable...Try extension socket
Phase 1 of shreddys plan achieved!
"Test dead."
I have one of these I've been meaning to unwrap and use:
Can't seem to find a "flying socket" at screwfix, donthey have other names?
Trailing socket.
Here's a Screwfix one, loads of others if you google as above.
http://www.screwfix.com/p/masterplug-heavy-duty-rewirable-13a-1-gang-single-pole-socket-white/89675?kpid=89675&cm_mmc=GoogleProduct Listing Ads
Sales Tracking
sales tracking url&gclid=CLOh1f6Dz9ICFQxmGwodW_cGDQ
Don't use that for testing for dead FFS.
Wrong range and it's possible there will be a black lump in what's left of your hand.
Hard to tell cable size supplying however it's rough as feck and certainly NOT compliant with regs even in 2006 . Done by a yeehah kitchen fitter that did 5 days electrical course and is now " Electrician" .
A 13A socket replacing the JUnction box ( looks like a 20A as too small for a 32A ) you will need to see what circuit protective device protects it though. Best advice is switch off at mains replace with a socket outlet and mounting box then plug new micro in .
As said DO NOT cut plug off , it won't void warranty , but it may mean you burn your house down if the new micro goes into fault.
Where is the OP located as if you are within an hour of E11 I will happily come and sort it for a beer or 2 .
I thought you would use the cable already there, as this just replaces the bodge box.Ah I found that, but it appears to have no cable - I suppose that can be bought seperately.
How so? I thought the pic shows 600V ac and 200V ac, one click and two clicks clockwise from the off position.Don't use that for testing for dead FFS.
What happens if you select the wrong range?How so? I thought the pic shows 600V ac and 200V ac, one click and two clicks clockwise from the off position.
Yes, but what I was responding to was the statement that it was the wrong range.What happens if you select the wrong range?
There's specific testing equipment available to test for dead to stop any mistakes like that.
I see now.Yes, but what I was responding to was the statement that it was the wrong range.
