Matthew_T
"Young and Ex-whippet"
- Prestatyn, North Wales
Following an incident that happened a while ago involving a van driver, I sent the company an email and this was the response I got:
His reply:
My most recent reply:
What do you think about his comments? Was my reply decent?
Dear P.A. Joinery & Property Maintenance
On 4/11/11 at 2.00pm I was a witness as to an act of agression with regards to one of your vehicles. I was waiting behind one of your vans who was having difficulty exiting Pendyffryn Road in Rhyl.
As this was the middle of the day, there was a lot of traffic about which compromised the capabilities of exiting the road. As the driver of DA54RXP had got frustrated with waiting patiently, they resorted to barging their way out, nearly hitting another car. They then furiously accellerated which caused the vans tires to loose grip and make a screeching noise. The van then turned left without indicating to no avail when the driver simply pulled into a car park.
I was disgusted at this standard of driving as the driver had a duty to not only complete his job, but publicise the business as well.
Attached is the video of the incident and I hope you deal with it accordingly.
Kind regards.
His reply:
I am a sole trader and I am the only person in control of this van.
As I can see there was no agression and I can assure you non was intended, just a wheel spin to what was caused by a heavy load in a front wheel driver van, the need for accellerating fast was to avoid causing an obstruction on a busy road as you did. The only danger on the road on your video was the red van needing to avoid hitting you and the white car that was in the centre of the road after you had pulled out in front of it. I do admit to 2 mistakes I made and they was the wheelspin which in the end cost me for new tires and not to indicate left which I apologise for and I assure you I was in the speed limit. I do find it very amusing that you have posted this on YouTube and will be making comments on the standard of your poor cycling.
Instead of trying to video drivers making mistakes please take care of your own safety on the road as it is very dangerous for cyclists as you well know.
Happy cycling.
Thank you for your response.
I understand that you were not going over the speed limit but you need to understand that spinning your wheels in any circumstance (apart from a failure of the vehicle) is against the law as it showed that you were not in full control of the vehicle. I acknowledge the fact that you were concerned for other drivers' safety but you could have accellerated rapidly without wheelspinning if you had been more conservative with the accellerator pedal.
With regards to my cycling, I opposed no obstruction to you at any point or to the red van (which I had an earlier encounter with).
I appreciate your concern for my safety though.
Kind regards.
