Paul_Smith SRCC
www.plsmith.co.uk
- Surrey UK
You may need to dish the wheel to get a straighter chain line, as a fixed hub is widerBrahan said:I have a thread on freewheel. Can that be used for a conversion?
A fixed sprocket lock ring can’t be used, not a vital addition for sure especially if using two brakes, but I still use one. You can use an old BB lock ring instead, the thread is the same direction and size as the sprocket, but it can be used if you really don’t want to run without a lockring.
The bike in the pic' above has horizontal dropouts and works perfectly OK, in some ways I prefer it as wheel is removed easier, plus leaning over/on bike when doing the rear wheel up tensions chain, drop out is long enough that I can always get correct tension as chain stretches.
Paul_Smith
www.corridori.co.uk
