dura ace brakes which dont open back up...
mr Mag00
rising member
Deepest Dorset
...like they used to. they are old brakes but they don not seem to spring back and end up touching the rim slightly which also highlighted the slight buckle to teh rim too. I pull open again
so why are they sticking and what can i do to remedy it?
cheers
Either
a)the spring has worn or muck has built up in the area where the brakes pivot (probably a bit of both). I'd take them apart,clean and then apply a drop of oil to them.
or
b)the brake cabling is naff.
A lazy person would take the wheel out and give metal part of the brakes a liberal quirt of WD40 from a variety of angles.
