Electric hoists. Can anybody give advice?
Milkfloat
An Peanut
Midlands
He'd have to get them back up the ramp though!
He could use an electric hoist.
MacB
[QUOTE 4920802, member: 76"]No. He is putting them in the loft, he will never see them again.[/QUOTE]
I'm not so sure it's a hoarding issue now, the story is just too flimsy, drawers and cupboards full of tools that he could easily carry up the ladder separately. Could probably have done it in the time he's taken inventing his poor excuse for this thread. Just have a think about the bare bones here, he wants to set up an electric hoist upstairs to raise and lower about 250kg. This has sex sling written all over it.
Bobario
We have a load of the Silverline ones pictured above at work and they are pretty decent for a cheap hoist. We've had more expensive ones that were worse. The cables start getting tangled if you are using them regularly so we replaced ours with Dyneema cord, but if you are only using it every now and again it shouldn't be a problem. You may need some brackets to fit your scaffold pole as the ones that come with the hoist are square to fit on a beam not a pole. There are four bolt holes on top of the winch frame to bolt them to. iirc they come complete with a bog standard three pin plug for power. Just make sure your pole and fixings are up to the job.
slowmotion
slowmotion
Quite dreadful
lost somewhere
Thanks for that. I think I'll discard the square beam brackets and cobble something together out of Kee fittings to take a standard scaffold tube.
slowmotion
slowmotion
Quite dreadful
lost somewhere
Right! @Bobario clinched it. I ordered a Silverline 500 watt jobbie. Pictures to follow. BTW, I'll be lying on a psychiatrist's couch for a few months before being able to show you my discreet loft-based dungeon.
Thanks all.
classic33
Leg End Member
Thanks all.
Aren't dungeons usually beneath a building, not at the top?
slowmotion
slowmotion
Quite dreadful
lost somewhere
Anything that goes in the loft is probably never going to come out the loft, so you may as well get rid.
Wrong, pal. Storing and accessing my stuff is just a button press away. Ordinary mortals can flounder about in the dark searching for their pitiful plastic Christmas trees while wetting themselves worrying about falling through their ceilings.
