BentMikey
Rider of Seolferwulf
- South London
Lurker said:Like the picture of the ASL in use, illustrating HC Rule 178, here
http://www.direct.gov.uk/en/TravelAndTransport/Highwaycode/DG_070332
you mean?
Look at this Jimbo - you are always harping on about the highway code:
178
Advanced stop lines. Some signal-controlled junctions have advanced stop lines to allow cycles to be positioned ahead of other traffic. Motorists, including motorcyclists, MUST stop at the first white line reached if the lights are amber or red and should avoid blocking the way or encroaching on the marked area at other times, e.g. if the junction ahead is blocked. If your vehicle has proceeded over the first white line at the time that the signal goes red, you MUST stop at the second white line, even if your vehicle is in the marked area. Allow cyclists time and space to move off when the green signal shows.
You are this: WRONG and FAIL of paying attention to the highway code.
