Erosion in the inner lining of the tire
velo0
I've bought many tires of different types, many of them had erosion where the inner layer becomes very worn to the point that the tire threads start cutting the inner tube and I have to change the tire at that point.
Loch side.
I'll try and help, but only if you like or otherwise acknowlege this post to prove that you are still around.
That is why I put baby powder on the inside of the tire. I feel it also helps the tube seat stress free.
fritz katzenjammer
Der Ubergrosserbudgie
Running it inside out to increase service life, as per the @Drago handbook of underwear management?
“Inside, outside, front and back… underwear has four working surfaces.”
chapter 1, verse 3 of Uncle Drago’s Rules of Underwear Management.
albion
Gateshead
Sounds more to do with riding with a flat tyre.
I suspect my use of a puncture protection liner is masking that problem on my rear tyre.
