yello said:
Thanks for helping out here MockCyclist. I was working blind, not knowing the particular GPS that btfb was using. Sounds like he's got it sussed now, or is certainly well on the way to it!
Thanks also due to NickM for posting the link to aukweb which had some really useful stuff for gps geeks:
http://www.aukweb.net/mag/index.htm
BTFB:
Battery life: I found a paid of AA batteries would last me a day and a half - probably 12 hours.
Route v. tracks. Ideally you need to be uploading routes to your gps. BikeRouteToaster produces tracks. It's possible to convert them to routes using gpsbabel. You can navigate using a track but you lose some of the functionality of the unit.
MockCyclist said:
You can store 50 routes, but I *think* the 1000 waypoint limit is for all 50.
That's wrong and if I'd thought about it properly I would have realised I have already had much more than that in my unit already. In fact I've successfully done a test upload of 50 routes with 241 points each and still had waypoint memory left. Really, you aren't likely to have any problem with capacity but using tracks isn't the way to go.
When navigating using your own routes, you don't really want to be using Auto Routing so you won't be limited to 50 points per route.
Auto Routing (on the gps, not on BikeRouteToaster) is best reserved for use with the "find" feature when you just want to get to your destination without having any input on the road you take.
Pretty much all the frustration you're having since my last post is down to trying to use a track. I'll try and put down a workflow for using bikeroutetoaster if I can (I don't use that site) but if you want to get a bit further in the short term I would suggest you create a route using MapSource, upload that and experiment with it.
To get you going, this is what to do:
On your gps, delete all your routes and tracks. Press the Find button, select Waypoints, and if you've got any, press Menu and delete the lot. Start clean.
In MapSource, go to Edit > Preferences > Routing tab. Select "Use Direct Routes".
Click the Route tool and draw yourself a route, by clicking on junctions or turns, these should be joined up with STRAIGHT lines. Start the route from where you have gps lock, in other words, from your home I presume.
In MapSource, of the four tabs Maps, Waypoints, Routes, Tracks, you should end up with a line on the Routes tab only.
Upload the Route to your gps and it should appear under the Routes icon.
Now, if you press Find, Waypoints, you MAY find that you have some waypoints even though you didn't have any before and you didn't select to transfer any. That's ok.
You must be able to get to this stage before you can proceed. When you do, select the Route and pick Navigate. Select Off road (that's important).
You should then end up with a map of your home area with a pink line starting your route. It will start as a straight line and may not follow your chosen road precisely.
