fitting drop bars to a flat bar racer
diabach
has anyone converted from flatbars to drops on a giant frc or similar.
is it an expensive option or should i consider changing bikes.
i know at some time iv"e read a past thread on this subject, can anyone help ?.. cheers...........
Sam Kennedy
Newcastle
Depends on your groupset, if you have a road specific one, all you need to buy is bars and shifters, should set you back about £150+ depending on what sort of quality you want.
If you don't have a road specific groupset, then you are far better off buying a road bike, since it will end up costing nearly the same to convert.
RecordAceFromNew
Swinging Member
West London
Usually the tricky thing is the brake (because V brakes and road calipers don't have the same cable pull ratios). But I believe the FCR has road brakes? If so the main things are a) fit, i.e. ensuring the stem / new bar combination suits your size/posture, and ;) the choice of brifters (which is likely to represent the lion's share of your new component cost) that are compatible with your specific drivetrain.
I converted a Specialized Sirrus LTD from flats to Drops. As the bike is a top end bike in the first place I decided not to skimp on upgrade. End result is that it cost me circa £500, which sounds like a lot of money, but for that I couldn't have got anywhere near the quality and spec if I'd bought a new bike for that amount.
