Many thanks.
.Did you really go for a L frame given you said you’re only 5’6??Many thanks.
From that I can see what details I need. Now I need to know how to get those details.
You may be (probably are) sharper than me but I cant see the required details on the manufacturers web site.
My bike is a Whyte Sirling in size L.
Will each flexible stem show thier details do you think???
Yes. I thoroughly test medium & large. On the medium the seat post was so far extended it was ridiculous. The seat was much higher than the bars**. Even my wife said it looked too small.Did you really go for a L frame given you said you’re only 5’6??
Whyte list the head angle as 70 degrees on the L Sterling, and the stem as 60mm extension. You can get the height based on what spacers are on your bike. It looks on the pictures like it's got 0 degree rise (i.e. it's a right angle to the fork) but you will be better placed to check on your bike.Many thanks.
No, as I said, its comfortable. The medium was too small.That's got to be way too big for you @Dave7
I am trying work out how much higher and how much shorter they can make the bar/reach.
Clearly not completely if you need to make adjustments to height and reach?No, as I said, its comfortable
