Markymark13
- Manchester
Is anybody planning to enter the Fred Whitton Sportive in May 2013? Anyone who has done it before, do you have any advice or tips?
Take cleat covers![]()
Fit low gears, and ride up as many hills as you can in preparation. Oh and fit SPDs so you can walk up and down Hardknott![]()
I'd be more worried about the down myself if it was wet.
I take it you are running campag ? You should be able to run a 13-29 cassette on the same rear mech.I am currently running a standard double, so lowest gearing is 39 26. Going to fit a compact in the New Year so that should knock it down to 34 26. Cant change the Cassette without buying a new reach mech, which I dont want to do.
Shimano mechs will take a good bit more than the instruction manual says. Changing to a compact will eat up some of the spare capacity, but based on my experience (with an extra-wide non-standard triple and a completely non-standard cassette) you might well get away with a 30T on the back, 28T will almost certainly be just fine.Nope, Shimano 2300. Can not afford anything more at the moment. The instruction manual states that 26 is the maximum number of teeth for the mech.
