I'm looking to buy a new front derailleur for my hybrid my crankset is 28, 38, 48 and 7 speed rear. Please can I get some advice on what I need? I see a lot of them are listed as mtb /hybrid. Is the derailleur dependent on the crank size... Thanks
Thanks, that's the exact one that I've just been looking at, think I might take a chance and buy it. Hopefully I can follow a tutorial on YouTube and get it ti line up correctly. My LBS is Halfrauds and they didn't do a great job last timeYou probably need a Shimano Tourney like this one http://www.evanscycles.com/products/shimano/tourney-tx51-hybrid-front-derailleur-triple-ec042714
Check the price as I think you can find even a bettrr deal somewhere else.
Thanks, hopefully the one I went for should be ok . It's top or bottom and the crank size is the same as mine. It should be delivered tomorrow so fingers crossedBefore you buy - some things you need to know....
Clamp sizes differ and the wrong size won't fit. Your current derailleur may state what size clamp it is - or you may need to measure.
Some front derailleurs are top pull and others are bottom pull - while some can be top or bottom pull. This means if the gear cable pulls the lever down from underneath it is bottom pull and if it pulls from above it is top pull. Make sure you get the right one or one that will work top or bottom.
