MonsterEnergy
What to do if your front Derailleur is bent and causes your chain to rattle against it?
well ive tried that but made it worse, although its fine at the minute but just depends what gear im in. I would take it to Halfords, but not at this Critical time with this Covid 19Straighten it if possible or buy a new one.
Carrera Vulcan Hardtail MTB. 3 gears at front, 8gears at back. I will post pic laterThey also come in top/bottom pull, top/bottom swing - quite a few variations. If you can post a picture that would help. Also type of bike, no of gears. Shimano derailleurs usually have a model number on the inside face somewhere.
metal is bentIs the metal bent or has it moved on its mount.
Ask Halfords to supply 👍 give your local open branch a call. Spec says it’s an AltusCarrera Vulcan Hardtail MTB. 3 gears at front, 8gears at back. I will post pic later
