mrmacmusic
- Tillicoultry
I'm looking to invest in a 'high beam' light for my unlit rural commute to complement my dynamo setup, but I'd like something with a remote switch that lets me switch on/off without reaching for the headlight itself and without looping through all the different modes... It looks to me like the Magicshine MJ-902 (or brighter 906) would fit the bill as from what I can tell, a long (ish) press on the remote will switch on/off and remember the mode – can anyone confirm if that's the case and if the MS lights are worth the money over cheap'n'cheerful high power lights which in my experience don't last 2 winters without problems...?
I am also considering a helmet mounted light to help illuminate where I turn my head as there are a few blind corners on my commute and would welcome any recommendations there... I don't fancy a trailing wire down my back to a battery pack and can't afford an Exposure Equinox mk2 (which admittedly would probably fulfil both head-light and helmet-light roles in one)... I figure with my dynamo headlight and a supplementary high-beam, any 'directional' helmet light wouldn't need to be particularly powerful...
Thoughts?
Thoughts?
However the mirror design and beam pattern cut-off on the Edelux II means that there are precious few stray photons above the horizon and yes, with 90lux it's nice and bright and gives good distance illumination (when aimed correctly) without dazzling oncoming traffic, cyclists and pedestrians. Perfect for the majority of my rural commute on back roads.
...you are correct.... it's part of the complete system, so you need a Garmin Edge to get the lights to work. It adjusts the brighness and beam direction according to how fast you ride.
