GaryA
Subversive Sage
- High Shields
If all you're after is the spore colour, the thing to do is take a spore print. Cut a hole in a white card large enough for the stalk, thread the stalk through the hole, and set the card on a tumbler for a few hours. Problem is, by the time you've got a decent print and identified your mushroom, it, and the rest in your basket, will have started to go off....Oh - how does one find the spores? Does one need a microscope to look at them? I assume each species have different spore morphologhy?
There is fascinating stuff to see in those spores, if you've got a microscope, but there you leave me behind...![]()
Ooh - sounds OK to me. I'm not eating any until I'm certain and then checked it with several experts first so the "going off" isn't an immediate problem.
Now with regard to those photos I posted way back in the beginning I'm beginning to wonder if the first "2 mushrooms aren't the same. I broke off bits of #1 and it had the similar orange layer. Eventually (and I may have not been patient enough before) it turned the winey red colour previously described. So apart from lack of oozing latex it might be Lactarius deterrimus. Corr it could take me donkeys' years to become a begining moderate Shroomer.
As for microscopy I have my Grandfather's microscope somewhere. It's just a beginners one. Must get it out and have a go (if I can find it first).
No it won't! You could learn in one or two seasons how to identify lots of the easier fungi. Have some help at first, but soon you'll be confident enough to pick them on your own! The ones in your photos are 'difficult' so forget those.Corr it could take me donkeys' years to become a begining moderate Shroomer.
Ah! You've touched on a major controversy there - amongst the mushrooming community it would be worthy of its very own P&L and generate more hot air than Campag v. Shimano or the H*lm*t debate....Do you take a knife with you when you go picking .... are you supposed to slice or pull up the mushroom, and do you need to slice it to identify it.
I'm trying to find a guided walk to go on ... I might have found one but its not until late November.
Ah! You've touched on a major controversy there - amongst the mushrooming community it would be worthy of its very own P&L and generate more hot air than Campag v. Shimano or the H*lm*t debate....![]()
...and a few other nasty things usually have a floppy membrane enclosing the base (for Fnaar's benefit, it's called a volva):
