Garmin Edge 1000 - How to change the time?
Spiderweb
Not So Special One
North Yorkshire
I’ve never had to change the time on my Garmin when UK clocks go forward/back as it usually does this automatically, unfortunately this hasn’t happened this time and the clock is an hour out. Does anyone know how I can change this?
Thank you in advance.
RoubaixCube
~Tribanese~
London, UK
Ive never heard of this ever happening. Maybe try hooking it up to a PC/Laptop and doing a sync
Also maybe check that you have the proper time zone set
If that fails then this follow the instructions on this forum - It seemed to have worked for this guy with a 520 - There is no reason why it shouldnt work for you
si_c
Wirral
Yep, either connect it to Garmin Connect via your phone or do a Sync via Garmin Express on your computer.
