Garmin800 please help
Payneys
Can anyone help
I am a complete computer fool ! No nothing about them have complete basic knowledge .
I have just purchased Garmin 800 with the GB DISCOVERER SD CARD
How do I even begin to download it to the device .
I have been trying every which way and have just all patience .
I have previosuly had an xt310 so I have a Garmin account etc
I just want to put the map on the device please help !!!
Thanks
potsy
Rambler
My Armchair
If the map is on a micro SD card it will fit into the device itself, in the appropriate slot.
At least it does on my 605 :thumbsup:
Gary E
Hampshire
Yep. The map card fits in the slot under the rubber cover (next to the charging point).
There's a setting on the Garmin to select which map to use (once you've installed the card you can select between the pre-installed maps that come with the 800 or the new ones you've just installed on the card)
P
Payneys
Not on mine - this is an sd card gb discoverer from Garmin - I see the slot you are saying but this ad card definitely doesn't fit in there .
Thanks for yr prompt replies .
P
Payneys
At least it does on my 605 :thumbsup:[/
Thnks yr reply no its not a micro sd card it will not fit . I have to download it to the computer and then upload to 800 but I just don't see how to do it
fatblokish
In bath
see the thumbnail slot in the sd card?; cleverly inserted into its bigger brother is a micro sd card. Pull on the thumbnail slot and the micro sd will emerge.
fatblokish
In bath
Now a Q from me.
Having bought a bigger volume micro sd card so I could get both the 1:50000 discoverer maps which came with the unit and some OSM maps I have downloaded, I find that the unit fails to recognise both. Must be summat to do with the format, but what?
ta
P
Payneys
Fatblokish - wish you had replied about 7 hours ago !! I found that little gem out by phoning Evans cycles .
For a complete idiot like me ( & apparently about 10 other people a week according to Evans) I fail to believe this very important bit of information isnt mentioned anywhere .
Thanks for yr reply in any case
Sorry I can't help with yr prob. But I really am a complete techno phobe !!!
berty bassett
I'boro
Now a Q from me.
ta
i think if they are both gmapsupp.img then it might only read one on device - if you have one on card and one on device it reads and mingles both if they are both ticked in settings - well thats what happens on 705
PK99
SW19
Now a Q from me.
ta
There is copy protection on the garmin supplied sd card
fatblokish
In bath
Both maps are on the new card, not the garmin supplied one.
I will investigate how to get one of the maps off the card and onto the GPS itself.
ta
