mickwood
- Chesterfield(ish)
Cool, I'd say that's more than enough for me at this stage. If it works out that I'm really using it a lot then it would justify the expense of the Satmap system.
summerdays said:I had my PDA/GPS going today... and recorded from 8.40 through to now (3.50), and according to the PDA I have 53% battery life left... though I doubt I would get another 7 hours worth. It is a large battery mind you - the case projects backwards at the back to accommodate it. I was route recording rather than using it lots to forward plan the route so that would require less batteries.
clownfishrob said:I've just bought a Road Angel 7000 for £100 on eBay which can be mounted on a bike and you can also upload memory maps to it as well it plots your progress using GPS and it can also be used in your car/motorbike/walking. Seems quite substantial but not had chance to road test it.
clownfishrob said:Well had the road angel 7000 now sold it. Biggest problem was memory map software is a real pain to use and the unit only has 8 hrs battery life. You can't easily charge it if you are camping either unless you want to carry a mains charger or some other specialist charging device like a power monkey.
