Perry
- East London/Essex
If you have, can you select all the gears on the rear when using the smaller crank?
Perry said:If you have, can you select all the gears on the rear when using the smaller crank?
yenrod said:Perry - from the left sprocket (no.1) of the block at the back your better going now further than 4 sprockets to the right...as the chain will be be TOO strained at an angle.
Chains work better in a straight line.
That's the problem with chains (chain stores... oh, never mind... where's me coat?)dantheman said:YES, IF ITS WORTH COMPLAINING, ITS WORTH GOING STRAIGHT TO THE top of management, then the branch and employees in the wrong will defo hear about it, and you should get great service then.. dont get fobbed off by a store manager..
... and then some for all the messing about!!Perry said:If I don't get any luck I will ask for my money back.
Focus Cayo off wiggle I think has this kind of spec - you can trial their bikes for a week too IIRC.But what other bike can I get with that spec (Ultegra)for a grand?
