T.M.H.N.E.T
- Northern Ireland
Consult a professional if in any doubt. Ignore the 220-age nonsense...
This formula was made up when first produced and has been widely discredited (not that it had credit in the first place, as the originating doctor has been at pains to make clear).As regards heart rate the rule of thumb is 220 - your age gives your maximum HR putting you at 170.
The worst a health check can do is tell you you’re OK, the best it can do is highlight a problem in time to prevent more serious events.
Surely a health check telling you you're OK is the best outcome, not the worst?Hi, got hrm because I was a bit curious as to what heart rate was, cheersI wouldn't bother with an HRM, just ride your bike. What benefit are you expecting from the HRM. Personally, I don't see the point unless you're training for something or a pro or maybe a cardiologist has told you to use one.
If concerned however, get checked by your GP
Hi, Ridings ok around kilmarnock, fairly quiet rural roads, cheers
Hi, thanks for reply .You said you’re three stone overweight and 51. Personally if I was you and concerned, which I presume you are by asking non qualified people on the web, I would see my GP and ask for a full health check. 40 pounds overweight is not healthy.
I’m 63 which puts me at 160 maximum. My resting HR averages 47, last Sunday I rode 63 miles, 5300 feet of climbing with an average HR of 133 and a maximum of 180. On a flat ride at 15/16 mph I would typically be around 105/110.
I had a heart attack two years ago. I’ve spoken to my GP and practice nurse about hitting 180 or so when climbing hard and they say carry on providing it’s only when working hard.
So all of the above is me, irrelevant to you. Strava is an app which tells you little really other than comparing past activity. My advice to all my friends these days is if you’re worried or don’t feel right see a GP. Men are very bad at this. Cycling or not an admitted 40+ pounds overweight means, for me, you should see a doctor and look at lifestyle regardless of cycling.
Apologies if this reads as a lecture. I’m quite passionate about men’s health since having a heart attack completely out of the blue. The worst a health check can do is tell you you’re OK, the best it can do is highlight a problem in time to prevent more serious events.
What's the correlation between heart rate and BP out of interest?
Suggest the OP reads the Wikipedia page
I doubt they will, which is why they won't be using that method, which is not useful for clinical purposes, in the first instance not being derived from original research, and in the second instance having a large standard error. These are the important things that clinicians will take into account when using a method for estimation.In my experience the NHS and British Heart Foundation would disagree with this view. I can’t argue the point but I’d be surprised if the NHS and BHF were misleading cardiac patients.
My heart rate was fairly high at my last medical , so I cut salt out of my diet completely.
Most foods have fair amount of salt in so I stopped adding salt to any foods and it helped in lowering bp.
Along with sensible diet and fitness it should reduce by itself , though as said some people do just have a high bp
