OrdinaryGuy1
First ever post in a cycling Forum and hoping they are not as vicious as Poker Forums :-)
I have been given a Giant Control Mini Pro Co2 pump and I want to use it as a manual pump not Co2 and for Schrader valves. Can I do that can I .....!!!
The Schrader bit is right at the end of the pump in-line with it so if you put it on the wheel you would be banging your hands into the spokes to do any pumping.
The Presta and Co2 bits are at right angles to the pump and obviously I want to get the Schrader into one of those positions.
I have managed to get the whole head off and remove the presta and co2 sides but cannot work out how to get the Schrader part at a right angle to the pump stem so I can use it
Any help will prevent a nervous breakdown!!! :-)
