figbat
Former slippery scientist
- South Oxfordshire, UK
I think you misheard them, if the cark is PARKED (ergo with engine off) and with electrical stuff running / connected it will drain the battery.
The alternator charges the battery whilst the engine is on, regardless of the position of the gear lever, although not charging as much when sat ticking over as it does on higher revs whilst driving.
Perhaps the point is that with a stop-start car, if you put it in PARK then the engine will shut down and will not restart to help with electrical load. If you keep it in DRIVE then the engine will restart to cover extra electrical demand if needed.
