Holdsworth 'Trentino' carbon....advice needed
Sloth
Hi, I have been offered a Holdsworth 'Trentino' carbon road bike (2014 Tiagra set up) and it could be a good deal.
However I know nothing about the brand other than it was owned by Planet X and may no longer be in production.
The seller claims it is a medium (men's) but from looking at pictures of the rear vertical frame post it is only 45cm from the pedal spindle to the top of the post (not counting the actual seat post itself). Now in my book that would make it a very small frame and possibly a women's but as I said I am not an expert.
Also, I have read that Holdsworth frames were often 'compact' and perhaps relied on a longer, extendable seat post and this may make their sizing different.
I can get no sense from Planet X and they don't have phone lines (I never buy new from a company that doesn't want to speak to me but as this is a private sale I suppose that's a moot point).
Does anyone know anything about this bike, is it any good and is the frame a small or is it a medium but using a different sizing methodology?
Thanks
Does geometry geeks have any measurements if not through Google. Presumably you’ll go try it before committing?
I expect it’s an open mould frameset painted in Holdsworth colours tho?
Sloth
Sloth
Planet X sent me this.....seems it's a small and too small for me anyway.
Spiderweb
Not So Special One
North Yorkshire
I think you’d be best asking the seller for the top tube measurement centre to centre, that’ll give you a better idea if it’ll fit you. If you have another bike that fits then compare those measurements.
It is difficult to size a bike with a compact frame geometry (sloping top tube). Top tubes can slope at different angles. if I remember correctly my Specialized Roubaix has a 47cm seat tube but it is a 54cm medium frame and my Hewitt has a 49cm seat tube yet that is also a medium frame.
Sloth
Sloth
Here's a few pics of the actual bike.
I am 5'8" with inside leg of between 30-31cm.
It is a compact geometry but it still looks smaller than a medium (i.e. I reckon 54cm is about right for me?)
iluvmybike
I'd not buy a bike unless I could go and see it and at least sit on it - frame dimensions differ so much between manufacturers it's not just seat tube length but also top tube length and looking at the phtotos the steerer has been cut so not much scope for raising the bars if required
Sloth
Sloth
The steerer has been what now? Cut?
I have one question....How does one tell this, why would they do it and what does it mean?
lejogger
Wirral
I'm not so sure it has been cut. There's lots of spacers under the stem, and a couple above. @iluvmybike is correct that the bars cannot be raised much higher (if at all) without flipping or replacing the stem though.
Most bikes come with plenty of excess steerer tube (extending from the top of the forks through the headset and stem. The idea being you put spacers (or not) under the stem to your ideal height and then cut off any excess that protrudes higher than 5mm above.
Obviously once one owner has done this, the forks are then useless for anyone who would prefer their stem any higher.
iluvmybike
That's 2 questions - ha ha! The steerer is the part of the fork that comes up through the headset and to which the handlebars clamp. On new bikes this is usually left uncut (ie at its manufactured length) as this allows the user scope in adjusting their personally required stack height. Once that has been satisfied it is normal then to cut the steerer to that length so that you don't end up with a length of steerer above the bars. If you require a lower stack height then it isn't an issue but if you wnat a higher stack height then it is as you have no scope for raising the height of the bars as it is now set at max height bar about a 5mm spacer max. You said yuo thought the bike was a bit on the smaller side for you so I'd suspect you may need to raise the bars.
T4tomo
in pictures
and only an issue is there isn't a stack of spacers where the green arrow is (or above the bars if they have gone for lower stack height without cutting the steerer to size) and even then you can flip the stem which looks neater than a stack of spacers.
moot point as it is the small frame, looking at the tape measure shots.
Spiderweb
Not So Special One
North Yorkshire
The steerer hasn't been cut.
Looking at the Geometry chart posted earlier it does look like the small frame, PX suggest up to 5’ 7”.
Can you try before you buy, you could look at a slightly longer stem maybe, it may just be ok?
